Beiträge von crazymao09
Yes, it worked perfectly, I left it stopped for more than 6 months and now it won't start. It only has a 36 PIN plug and a catalytic converter too
on the file it says that the first registration is from 03.11.1995 I don't know, that says
in the mfu there is no yellow/brown wire is it possible? the yellow/brown and grey/blue wires from the injector come out of the ecu
ok, I'll look at all this, thank you very much for your answers
Hello, thank you very much for your help, if it takes 3 seconds, 2 wires arrive at the injector, one yellow/brown and one blue/gray that come out of the ECU, both have continuity but 12v does not arrive. 5 v AC comes out from the crankshaft sensor when starting is tested
ok, so I connect the white/pink to ground and the 5as would be deactivated, right?
What color is the immobilizer wire 23?
Hello, if all this is verified, the pump primes for about 10 seconds, 12 v reaches the coil but no current reaches the injector and the starter remains activated in the relay package but none else,
ok, thanks, I have a problem that my spi does not start, I have tried everything and I see that there is no power to the injector, could it be a problem with the ECU? thank you
Hola, tienes algúna caja de relés para spi? Gracias
Hola,me supongo que está vendido ,no?
Hola,tengo en mi spi del 95 una mne101070,he leído aquí en el foro que no lleva inmovilizador,pero yo sí que llevo en mi coche,o eso creo,tengo un lucas 5as detrás del tablero y mando.alguien me puede explicar? O solo es alarma?
Por cuanto lo vendes?
hola me interesa el relé
Hola, busco modulo de relais para spi, si alguien vende que me informe, gracias
Hola aún tienes los relés?
