Beiträge von Nicklouse
not quite sure if they understood my request for part of the work which was a shame.
but cleaning up the block and head surfaces they can do and we will see what the crank is like when i pull it out later.
Ok made a move on a bit more get that nut off
then check the MED support will fit without any modification
placed in place without gasket
stripped ready for machining and cleaningoh and these blind bearing pullers. they work but i would not want to be using them often as they are not great and need some modification.
auf der Suche nach einem Dichtungssatz für meinen 1300er bin ich auf einen Dichtungssatz von Ajusa, einem Dichtungshersteller aus Spanien, gestoßen.Der Satz wird für einen 12H Motor gelistet, meiner hat die Motornummer 12A2A...
Wo liegt den der Unterschied? Bisher habe ich folgendes gefunden: http://www.theminiforum.co.uk/forums/topic/172555-mini-engines/
Also bleifrei und verbleit.... das heißt, dass ich den Dichtungssatz verwenden könne müsste, oder?
Danke für kurze Info & Grüße,
Nobbyvery little difference. you may find one does not have all the gaskets you need for your original set up.
i see prices that are for fun BUT give me a price for the following. shipping to Mainz.
1/2-9/16
stubby s
9/16
11/16
3/4
and the standard
11/16
PM is OK and if the price is acceptable you may have a sale.bare in mind that i have managed for years with out snap-on spanners.
Bergi the problem you have is you want longer studs to fit 10mm spacers to S discs.
there are no studs of the correct shape IE will fit the disc and clear the caliper. again dont go grinding the heads down. they do pull through the disc/drive flange due to the change in the metal properties. the length you want to do what you thing you need just dont exist.
dont forget you will need to cut the wings as you are changing the geometry that much by changing the wheel ET by adding 10mm spacer.
right. slight change of plan.
as i have spent the cash on a dog gear set i no longer really need a pre filter. but there was a problem with the bits i wanted. i wanted to fit a oil temp gauge but i also wanted AN8 hose and fitting not AN6 so a chat with DSN lead to a chat to SC with resulted in this delivery. the other bits well my self made welded up rear mounts might be past it now.
the front mounts. why not-
Nice. Close as well. -
cheers andy i have seen them but have no idea if they knew the A series. looks like i will be visiting them.
