Einige Teile auf Ebay:
Gebraucht:
- Lucas STF576 spotlamp -> Ebay
- Innocenti 1001 speedo set -> Ebay
- Two sets of double valve springs taken from 12G295 heads. All 32 springs go as one lot to allow you cherry pick the most suitable ones -> Ebay
- 7 inlet valves for 12G295. All go as one lot for you to cherry pick the 4 best -> Ebay
- 8 exhaust valves for 12G295. All go as one lot for you to select the 4 best -> Ebay
- Piston set for 998 Cooper D-tops in std size -> Ebay
- Piston set 19320 in +40 for Cooper S -> Ebay
Gebraucht und mit ein Problem:
- AEG510 Cooper S Mk I/II camshaft with 0.003" step in oil-pump side bearing -> Ebay
