MED S/C Zwischenradsatz
  • Geradeverzahnter Zwischenradsatz MED "Roller Type"
    http://www.med-engineering.co.uk/catalogue/gear…set-roller-type
    Ich habe einen kompletten Satz (1:1) geradeverzahnte Zwischenräder
    von MED zu verkaufen. Passt bei allen A+ Getrieben!
    MED STRAIGHT CUT DROP GEAR SET ROLLER TYPE
    A must for any competition engine build. We have been manufacturing these gears for many years now with great success. They make a indestructible drop gear set. The middle idler gear has a straight roller bearing built into the middle of the gear. It runs on a steel shaft which is fitted into the gearbox in place of the standard idler bearing which is commonly know to work loose on competition engines and cease the idler gear causing catastrophic failure to the transmission. A steel top hat then replaces the idler bearing within the transmission housing which encapsulates the ider gear assembly when fitted. There is no need for any shimming as all tolerances are taken up within the gear assembly, this itself can save time and further expense on over/under size shims. Available in three ratios as below, sold in engine sets of 1 x primary, 1 x roller bearing idler and 1 x input.
    War nur 2 Jahre bei mir im Einsatz und ist ohne Beschädigungen
    in sehr gutem (neuwertigen) Zustand!
    Preis: 300,00 EUR inkl. Versand
    Marco
