Trim | Application | Comment |
10" hubcaps | ||
1959 hubcap | Note the square cutouts. One piece. |
Later hubcap | Note the round cutouts. One piece. |
Innocenti Mini Minor (Mk1, 1967) hubcap | |
Small standard hubcap | Covers just the middle of the wheel. |
Authi hubcap | As fitted to Authis. Made of aluminium! |
Clubman type | |
Innocenti (Mk1?) | Standard hubcap for italian build Innocenti Minis. |
Innocenti 1001/B38 | Standard hubcap for italian build Innocenti 1001. |
Australian type | |
Australian Mini 'LE' hubcap | |
Wolseley Hornet (MkIII) hubcap | |
Riley Elf (MkIII) hubcap | |
Benelite hubcap | Aftermarked item, propably early 60's. |
Australian aftermarket hubcap | Aftermarked item from the 60's. |
Aftermarket hubcap | Aftermarked item, propably 60's or 70's. |
Aftermarket hubcap from Italy | Aftermarked item, propably 60's or 70's. |
Aftermarket 'Turbo' style hubcap | Aftermarked item, propably 70's or 80's. |
Late type plastic hubcap. | Mini HLE, Special, Clubman, ... |
Unknown Plastic hubcap. | Probably 80s? |
Trim 9. | Aftermarket item. |
Aftermarket item. | |
Plastic Hubcap | From France, sold for trailers and caravans. |
10" trims | ||
Trim 1. | These rings are mounted under the small standart hubcaps to give a different look. |
Trim 2. | Used on Clubman models, together with Clubman type hubcap. |
Trim 3. | |
Trim 4. | |
Trim 5. | |
Trim 6. | |
Trim 7. | |
Trim 8. | |
12" hubcaps | ||
Clubman 1275GT, 'Denovo' wheel hubcap. |
Mini 25, 1984 | First Mini (exept of 1275GT) with 12" wheels. 12" wheels and the 8.4" brake became standart fitment with the Mini 25. |
Std. Rover steel wheel centre cap. | |
Mini, 1980´s | Note: this one has a Austin logo in the centre |
Mini Special, 1990´s | Plain center |
Mini Mayfair/Mayfair Sport, 1990´s | |
Rover standard hubcap | |
Mini Le and HLE (plus propably others) | |
Innocenti 90/120L | |
Chrome center for 12" Rover steel wheels. | Held in place by the wheelnuts (special requirement). |
Unknown hubcap & chrom ring. | Ring maybe from Hilmann Imp? |
Other... | ||
Mini Metro | |
MG Metro | |
NAM6545NN, Metro 1275 Sport | |
Moon discs | Aftermarket item.
You can buy them HERE: http://www.bamdltd.co.uk |
