Rim | Name and size | Offset (if known) | Notes |
Cooper Car Company 'Rosepetal', 4.5x10" | The original 8 spoke design wheel. Made by the Cooper Car Company. It's a 'copy' of the wheels used by Cooper for Formula racers. The Minilite design was copied from the 'Rosepetal', but is more famous today. |
'Rosepetal' 6x10" | Picture (c) Casper Sparsöe. | Made for 18 times Danish Champ winner Erik Hoejer by Ole Rytter (Denmark). The same man who also, in '66-'68, made the first alloy 7 port heads, which were the brainchild of Erik Hoejer's race mechanic Poul Heickendorff. The heads which later became the base for the iron copys by AKM (and then MiniSport). Only 2 sets know to exist. |
'Rosepetal' 4.75x10", recast | 80's Cooper Car Co. cast of the Rosepetal | |
Vortz 'Rosepetal' 4.75x10" | Vortz bought the Cooper Car Co's original tooling and continues to make the 'original' Rosepetal. Added 'Vortz' logo on outer edge. |
Vortz 'Rosepetal' 4.75x10" | Limited batch made without the 'Vortz' logo. | |
MiniSpares Center 'Rosepetal' 4.75x10" | ET40 | Modern reproduktion by MiniSpares Ltd. Part n° C-21A1071. |
CR wheels, 4.5x10" | ||
CR wheels, 5x10" | Fit w/ 165/70 tyres w/out arches
Still in production in smal numbers in Japan. Copy of the famous Rose Petals |
CR wheels magnesium, 5x10" | ||
Early Minilite Magnesium, 4.5x10" | The groove dissapeared ~1967 | |
Minilite Magnesium, 4.5x10" | ||
Minilite Magnesium, 5.5x10" | ||
Minilite alloy, 4.5x10" | ||
Minilite alloy, 6x10" | ||
Minilite Generation II, 6x10" | ET-15 | Modern designed, 'dished' Minilite. 3.4kg. |
100+, 5x10" | ||
RS Watanabe, 6x10" | ||
Enkei [E152?], 4.5x10" | ET40 | |
Enkei, 5x10" | ET16 | |
Span Mag, 6x10" | Made in New Zealand by Papakura Metal Foundry. Available in a range of widths up to 9inches. |
Ward, 5.5x10" | Originally made as Ward wheels in Palmerston North N.Z. Were later made better and with a nicer finish by Aldic and became regulation wheel for N.Z. Mini seven racing, Group NB. |
Aldic, 5.5x10" | ||
Fraser, 5.5x10" | Again a copy of the Ward wheel. Fraser made about 100 of them. Any more info greatly appreciated! |
Minilife works replica, 4.5x10" | Fits without wheel arch extensions. | |
Minilight, 6x10" | ||
BWA Racing 'GB', early design (70's), 5x10" | ||
BWA Racing 'GB', later design, 5x10" | ET21 | Commonly only known as 'GB'. Manufactured by 'BWA Racing' http://www.bwawheels.it/ |
BWA Racing 'GB', 6x10" | ||
Boomerang, 5x10" | Italian made | |
Unknown 46, 4.5x10" | Unknown Minilite-Style wheel, most probably from Italy. No marks. Can anyone identifie this wheel? Looks similar to the Carmona, but has much smaler seats for nuts. Nuts are a combination of sleeve & tapered seat. |
Carmona, 5x10" | ||
KN Minator, 5x10" | ET19 | |
KN Minator, 6x10" | ET6 | |
MWS, 4.5x10" | ||
MWS, 5x10" | This 5X10" wheel was designed for use with drum brakes and will not fit the Cooper S brake. |
PEG Mistral, 5x10 | Came out std. fitment in quite a few Minis in South Africa |
Performance, 5x10" | Performance Australia | |
ROH 'Contesta', 4.5x10" | Also came in 5x12" and 6x13". Compliments from GT mowog in Oz. |
ROH 'Contesta', 5x10" | Note how the 'spokes' are recessed below the outer edge. |
Ultralite, 6x10" | ||
Image Split Rims, 6x10" | ||
Valtain, 5x10" | ||
Unknown 50, 5x10" | Lettering: "MINI 5J-10" |
